Rear lock on CQ
Old Oct 23, 2006 | 09:18 PM
Ringnalda's Avatar
Default Rear lock on CQ
Well bought some goodies at a local wrecking yard, which included a rear lock from a 90Q sedan. (Mine didn't have functional power locking) I compared quickly with my CQ and it looked the same. After switching the barrel around and other hardware, come to find that one of the tabs is 10 degrees different between the two. Can't bolt this sucker in...! Nice interchangeability...NOT! Anyone has a coupe lock in good shape?
Old Oct 24, 2006 | 03:28 AM
520's Avatar
520
get me one while you are at it;-) It seems all of us need one.
Old Oct 24, 2006 | 04:58 AM
Regenmeister's Avatar
Senior Member
Default Rear lock on CQ also has an inherrent weakness in it's design & mfg.....
The hatch on the CQ is heavier than the sedans even thou it is FG and the CQ does not dissipate air pressure inside of it as easily as the sedans, you have too shut more than once to make sure the lock engages or open a door slightly to relieve the sadi pressure. Most owners don't bother with the slight door openeing sooooooooo they slam the hatch. This causes the said weakness. The cast metal arm on the lock breaks or cracks leading to improper operation of the lock. You'll know it isn't working properly when you try to open it from the different positons on the lock
Old Oct 24, 2006 | 08:22 AM
Ringnalda's Avatar
Default Re: Rear lock on CQ
Part two of the saga. The power lock latch was broken. The lock casing was different to the 90Q (previous post) but the mechanism was identical. So I drilled out the pivot pin, and replaced the broken part in my lock. reduced the spring size (slightly) so the ball pressure is reduced. Also switched the barrel (again) and rebuilt the whole thing. All is well now... Finally. Now the heat flow actuator...
lsher
Q7 MK 1 Discussion
37
Apr 13, 2022 06:40 PM
Butts
Audi allroad
Apr 6, 2018 04:46 AM
Ride2Live
Audi allroad
Aug 2, 2012 05:27 AM
indusCreed
A4 (B7 Platform) Discussion
Feb 10, 2006 04:29 AM
green88'90Q
Mar 18, 2004 06:23 AM
