I refurbished my front anti-sway brackets...
Old Oct 24, 2006 | 06:37 PM
Brdman*'s Avatar
Default I refurbished my front anti-sway brackets...
car drives differently without the front bar... i sort of like it. It does 'sway' more, but feels more predictable in initial turn-in. That bar is HEAVY too...
<img src="http://pictureposter.audiworld.com/37457/sways.jpg">
Old Oct 24, 2006 | 06:58 PM
Cq20V's Avatar
That make it go faster?
Old Oct 24, 2006 | 07:01 PM
Brdman*'s Avatar
i gave up on fast awhile ago
Old Oct 24, 2006 | 07:05 PM
CastleCQ's Avatar
New Member
those look a lot nicer than the ones I'm trying to fab onto the rear of my car.
Old Oct 24, 2006 | 07:34 PM
Merkin's Avatar
AudiWorld Expert
i modded an Energy suspension universal kit for my front
Old Oct 25, 2006 | 05:26 AM
Zzak's Avatar
What suspension are you running? Just curious as I'm planning on removing my front bar.
Old Oct 25, 2006 | 06:40 AM
JPCady's Avatar
Default 2nd...But for the rear...recommended!
I ordered from jegs.com. Good product, and pretty cheap! Not sure about the front, but the rear was pretty easy.
Jake
Old Oct 25, 2006 | 07:54 AM
Brdman*'s Avatar
bilstein &amp; stock sport springs
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 25, 2006 | 08:32 AM
q20v's Avatar
Default Did you get the 26 or 25mm bushings?
The 26 requires going up to the bigger size bracket... or did you just modify the 25mm to fit? Is it the 26mm bar you have on the rear, right?
I tried jegs.com but its an additional 40 dollars (30 for parts) to get it shipped to canada, gonna try some local speed shops.
Thanks for any help JP!
Old Oct 25, 2006 | 02:21 PM
JPCady's Avatar
Default I think i got the 1-1/16" bushing...and it fit no problem, but it was a while ago
if I recall correctly, 1-1/16" = 26mm or close enough. Through Jegs it was only $14us....check out the link <a href="http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10002&cata logIdentifier=Jegs_Direct&categoryId=13009&parentC ategoryId=10059">jegs.com</a>
Jake
