crazy brake hiss. can't figure it out.
Old Oct 25, 2006 | 08:48 AM
coupe d'mike's Avatar
Senior Member
Default crazy brake hiss. can't figure it out.
so far, i know it's not the cruise control module, don't think it's the master, but it could be.
symptoms: constant hiss inside the car. goes away when i apply slight pressure to the pedal. when i start the car, the brake light is one for a second, then stays off.
drives me crazy, and is probably not too safe.
Old Oct 25, 2006 | 08:56 AM
520's Avatar
520
Mine went away after a bit...if you remember I had it too.
Old Oct 25, 2006 | 09:00 AM
Regenmeister's Avatar
Senior Member
Default Ok I think I may have posted this before but if you are hearing a hissing...
down there and you know absolutely 100% sure that it isn't a leak in the vacuum lines & valves connected to the brake & gas pedals from the Cruise Control...then if are you not hearing the heater shutter closing & opening at start up...you are hearing vacuum leaking out one of the lines that controls the shutters behind the dash for the Climate Control system.
Old Oct 25, 2006 | 09:10 AM
Senior Member
Default yep, i thought yours was the cruise module. mine's been like this for a year or so...
usually i just turn my stereo up, but it's freaking me out a bit
Old Oct 25, 2006 | 09:47 AM
520's Avatar
520
but why would stepping on brakes stop it?
Old Oct 25, 2006 | 10:03 AM
Senior Member
Default Ever see the position of the junction box for the lines? Right next to the peddles.
I'm wondering if one of the lines is getting pinched by the braking action.
Old Oct 26, 2006 | 07:44 AM
Senior Member
ahhh. worth another look.
Charlie Brown 99
13
Feb 11, 2007 07:27 AM
PhaZeIII
12
Dec 10, 2004 09:58 AM
coupe d'mike
Oct 12, 2004 06:16 PM
Digger Killer
15
Sep 25, 2003 05:11 AM
MTUJT
Jul 21, 2003 06:49 PM
