Running lights not working, so I replace the r/r corner bulb...
Old Oct 25, 2006 | 01:35 PM
gumper's Avatar
Default Running lights not working, so I replace the r/r corner bulb...
<center><img src="http://pictureposter.audiworld.com/112768/brides_ride.t.jpg"></center><p>that didn't solve the problem. Now I get a buzzing sound from under the dash when I turn on the turn signal. What kind of fool am I?
Old Oct 25, 2006 | 01:37 PM
CvTech's Avatar
relay
Old Oct 25, 2006 | 01:52 PM
gumper's Avatar
Default Would my '93 90 sedan/parts car have this same relay?
<center><img src="http://pictureposter.audiworld.com/112768/brides_ride.t.jpg"></center><p>Would you be able to describe it to me (part number)? Would this same relay be responsible for some other lighting issues?? Only the right signal &amp; break light are working. No running lights on right side at rear.
Old Oct 25, 2006 | 04:10 PM
Luxus Panzer's Avatar
hold on...got my Bentley back....I will look it up.
Old Oct 25, 2006 | 04:16 PM
Default no relay for rear or running lights listed in either relay pannel or aux relay pannel....
what is working and what is not?
did you check the fuze?
Also check your wireing allong the rear hatch. You might have the CQ's version of the B4 trunk wire harness problem.
Old Oct 25, 2006 | 04:33 PM
CvTech's Avatar
turn signal relay?
Old Oct 25, 2006 | 06:14 PM
SCarGo02's Avatar
Um, Bentley doesn't list part numbers and if you're using ETKA, you don't know how to...
Old Oct 25, 2006 | 06:16 PM
SCarGo02's Avatar
Default As far as the relay goes, drop one of your panels above the pedals...check the relay diagram...
...for the turn signal relay...take it out of the parts car, compare it to the one in the working car. If they're the same part number, you're good to go...this isn't rocket science.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 25, 2006 | 06:19 PM
SCarGo02's Avatar
Are you sure the bulb isn't jammed in backwards?
Old Oct 26, 2006 | 02:47 AM
not looking for a part number...looking for a location....why don't you find it in ETKA then?
