question about LED's... FOR MY CQ!
Where:
E is voltage
I is amperage
R is resistance
Use that to figure out the size of resistor you'll need if you want to just put one in line with the whole group of LED's. Check out the link below for more info. If the draw is high enough, make sure you get a resistor that can handle enough current.<ul><li><a href="http://www.the12volt.com/ohm/ohmslaw.asp">Ohm's Law</a></li></ul>
