Sealing cord for...
Old Oct 27, 2006 | 05:29 AM
CactusGreen's Avatar
Default Sealing cord for...
the waterguard under the windscreen?? Just replaced the pollen filter on my cabriolet, and can't get the water/leafguard to sit properly and make the seal...there was something like black sealant in a bead on the underside which I assumed was a previous 'bodge fix' to hold it down, but a close look on my ETKA lists a sealing cord AKD 497 010 04...which my dealer has never used....
It's stll listed as avaialble, but as they have none, it's specal order and not cheap...despite it being listed for all the 80/90/100 and B5 A4's as a required part!!
So - have you all got this in place or just poor fitting and water leaks??
Old Oct 27, 2006 | 05:42 AM
SCarGo02's Avatar
Default You could buy some butyl sealing cord used for setting auto glass...
...a roll of it here is about $10-15 at an auto parts supply store. It comes in a 3/8" bead...it's the same stuff used to seal tail lights and such too...
Old Oct 27, 2006 | 06:51 AM
Default Re: You could buy some butyl sealing cord used for setting auto glass...
I'd asked about this when I had the screen on my A4 changed last week - they had not seen anything like that before...maybe we don't use such things over this side of the pond??
Old Oct 27, 2006 | 07:03 AM
Regenmeister's Avatar
Senior Member
WURTH sells it in the UK. The guys at the UK S2 Forum can help you find it.
Old Oct 27, 2006 | 07:40 AM
Default got a link to that forum??
This looks like the stuff??<ul><li><a href="http://www.wurth.co.uk/catalogue/pdfs/UK-CD_03_0015.pdf">Wurth</a></li></ul>
Old Oct 27, 2006 | 01:52 PM
weldhot's Avatar
Default Re: Sealing cord for...
Hi. purchased 1 roll to reseal my coupe drivers rear light from Ebay 27/10/06 cost 8.5 GBP + postage(1 x roll is approx 2.5M) Item i think. is still availble. VAG Part No AKD49701004R10 is for a box of 4 rolls i belive, hope this may help. cheers
Old Oct 27, 2006 | 07:09 PM
jitsu303's Avatar
Default 3M Strip Chaulk $20 for 20 feet IIRC
Widely available over here...must be 3M retailers in the UK? If you're really stuck, you can get it from Eastwood or I can pick it up here and post it.
Old Oct 27, 2006 | 11:48 PM
Default Re: 3M Strip Chaulk $20 for 20 feet IIRC
Thanks, will look into it :-)
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 27, 2006 | 11:50 PM
That sounds right, was told it was for 10m of the stuff....and it would cost me ?28.20 inc vat ($53 !! )
A4orce84
Feb 28, 2005 09:07 AM
A4psi
Quattro: Turbo / Ur / Sport
Apr 29, 2004 09:52 AM
Jestyr
Auto Detailing Discussion
Jul 28, 2003 09:17 PM
Jeff Doble
Jul 16, 2003 06:38 PM
The Devil
Jan 30, 2002 05:22 PM
