you gotta be KIDDING me...
I get in the car today, and it starts right up...but hangs at around 8v. NOW what....yesterday it read 14
The shop gave me a test light, to pull codes, but ive never done it before...does anyone have pictures of what to do?
I assumed that the alt wasnt putting out the right volts, and i was running off my batt....so i just turned around, and parked it.
hmmm...cant hurt to get a new VR...can we be mostly sure the alt is fine? I WAS told it was a new alt when i got the car about a month ago...
<i>Insert a bulb into the "Check Engine" light in the instrument cluster. Only California market cars had this bulb installed, but all cars are wired for it. When this bulb is installed, it can be used to flash the ECU fault codes. All you need to trigger the fault code output is two pieces of wire connected to the A1 and B1 slots in the driver's footwell. As an added bonus, it will flash whenever a fault code is registered, telling you it's time to pull the codes.</i>
