anyone have the problem of your outside temp reading really really low?
Now it doesn't seem that bad but then again, not quite right..
Must be the sensor I guess ?
requires soldering, but overall, could be a fun little project.
Unplug the front temp sensor that was attached to your B3 grill. (I have B4 as well, so I just zip-tied the sensor somewhere)
Then using needlenose pull the sensor out from the plastic shroud. Unfortunately mine was completely destroyed when I took it out.<ul><li><a href="http://www.digikey.com">Use: KC016N-ND as part #</a></li></ul>
