ABS switch partly resolved
Old Nov 1, 2006 | 04:16 PM
Ringnalda's Avatar
Default ABS switch partly resolved
I replaced the ABS switch in the console, now when I press it, the ABS warning light comes on so it was indeed the switch. I still don't get an orange or yellow triangle in the switch but that could be a switch illumination problem. What is the easiest way to get to the actuator which regulates air from the vents to the windshield? Mine does not change. ALso the heater control seems to be unreliable.
Old Nov 1, 2006 | 04:31 PM
Luxus Panzer's Avatar
Default 1=replace bulb in ABS switch. 2= U seem to have eletrical gremlins...check...
your trunk wire harness and your ignition switch.
If you have never repalced your ignition switch...do so....it is cheep as far as audis go
Old Nov 1, 2006 | 04:32 PM
SCarGo02's Avatar
Default To get to the flaps & heater core the whole dash has to come out - check the tech section...
...dragon-ryder did an excellent write-up!
Old Nov 1, 2006 | 04:33 PM
SCarGo02's Avatar
Default Um, he's talking about the flaps for the vents & the heater core...that's all buried behind...
...the dash...
Old Nov 1, 2006 | 04:52 PM
Brdman*'s Avatar
Default haha! moderator.
that's classic
Old Nov 1, 2006 | 04:53 PM
SCarGo02's Avatar
Hmm? Been that way for a while now...
Old Nov 1, 2006 | 06:05 PM
Ringnalda's Avatar
Default Re: haha! moderator.
Can I get to the actuator if I take the center console out?
Old Nov 1, 2006 | 06:55 PM
Brdman*'s Avatar
you can get to the *****, check to see if they are working first.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 2, 2006 | 03:41 AM
Ringnalda's Avatar
Default Re: you can get to the *****, check to see if they are working first.
Ahem. No *****. Just a digital display and a choice between cabin or windshield. I have bought a new controller but suspect it could also be an actuator.
Old Nov 2, 2006 | 08:49 AM
Brdman*'s Avatar
Default you can pull diagnostic codes from the digital display CC...
<ul><li><a href="https://www.audiworld.com/tech/elec.html">There is a tech article about it somewhere here</a></li></ul>
audidrvr
Audi Original "S" Cars
Nov 17, 2008 12:58 PM
c4S6
May 27, 2007 05:06 PM
Shane7452
Dec 28, 2005 07:52 AM
Regenmeister
Nov 21, 2005 11:02 AM
Regenmeister
Nov 18, 2005 08:14 AM
