P.O.S.: A4 Avant Flat-bedded 3 times in 1.5 years
I just had to have the A4 towed for the 3rd time after the roller pulley for the timing belt broke leaving me stranded. There is valve damage, and the cylinder heads are f****d. If I had driven 6000 more miles before this happened, my warranty would have run out and I'd have to shell out $4000 of my own money. Luckily the extended warranty seems to be the only thing about this car that doesn't suck. Oh yeah, it needs a new rocker arm and suspension work as well. What else has been repaired so far you may ask...let's see...the whole front end (grill, bumper hood, radiator) after the dealership ran it into another car on the lot; the coolant temp. sensor (twice), the cup holders (twice); the center counsol; two coils; the sparkplug wires; a lug nut that the dealer forgot to tighten; the driver's side mirror (mechanical issues); two sets of headlights have burned out for no apparent reason; and there has been much more, but I can't think of it off the top of my head.
Just had to vent about this POS. I'm selling before the Audi Assured warranty is expired. Probably won't be back in the market for an Audi though.
Its unfortunate that they made such a sweet looking car one of the most unreliable cars on the market.
For what it's worth, aside from 3 CP failures (known defect on the 2001+ MY), my car has been flawless - not a single issue. *knocks on wood*
Lemon laws, IIRC, apply when the same problem has been attempted to be fixed unsuccessfully three times. I don't think it applies to multiple separate issues. Check with your state, though.
take a dose of common sense. when you move into a house that had a previous owner, don't you look around, see what needs to be done maintenance-wise, then have it done? or is that just me.
