Quick question about 235 tires
Old Jun 4, 2003 | 05:01 AM
FatAuto's Avatar
Default Quick question about 235 tires
I have searched and done reasearch and ordered 235 45 17 tires for my new BBS VZ's 17x8. TireRack just called and said it will rub on the front suspention, especially when I lower it with the Koni Coil Overs I also just ordered. Eddie had said that the only rubbing may occure on the lip, which rolling can eliminate. Whats the deal here? is it the lip or suspention....I'm pretty sure I'm ok here, but want to make sure. By the way it's a 99.5 2.8 QM
Old Jun 4, 2003 | 05:21 AM
Digit@lex's Avatar
AudiWorld Expert
Default If the offset is too large (i.e less than 32mm)
than the wheels will be too close to the suspension and that will cause rubbing. Also, depending on the suspension which may be larger in diameter, it could contribute to rubbing as well.
Old Jun 4, 2003 | 05:29 AM
FatAuto's Avatar
ET 35
Old Jun 4, 2003 | 05:35 AM
Digit@lex's Avatar
AudiWorld Expert
Default Offset is the same as mine.
And I have 18x8.5s as well as 235/40/18 tires and no suspension rubbing. I had my fenders rolled too. I don't have Koni COs though so I couldn't tell you about possible rubbing. I'm running Neuspeed Sport Springs and grooved Bilsteins.
Old Jun 4, 2003 | 05:41 AM
FatAuto's Avatar
Good enough for me....calling them back to place order.
Old Jun 4, 2003 | 06:13 AM
skabaru's Avatar
235/40/17, not 235/45/17.
Old Jun 4, 2003 | 09:53 AM
AddictedA4's Avatar
i have 235 45 17-- i rub a bit on hard dips but rolling fenders will fix that
Old Jun 4, 2003 | 10:59 AM
oldkenobi's Avatar
Junior Member
wont 235/45/17 be an increase in overall diameter?
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 4, 2003 | 12:07 PM
AddictedA4's Avatar
Default im about 1.8% off -- on the high end
heres a tire size calculator
Old Jun 4, 2003 | 12:33 PM
Digit@lex's Avatar
AudiWorld Expert
I'm off too using 235/40/18 but it's worth the extra rim protection IMO.
