are there any negative effects with running race fuel (100 octane)?
Old Jun 4, 2003 | 10:35 AM
How Bizarre's Avatar
Default are there any negative effects with running race fuel (100 octane)?
my 2001 1.8t is pinging, so i want to try some race fuel to see if it'll help. i've got a giac x-chip and an spp fmic. thanks.
Old Jun 4, 2003 | 10:37 AM
paul_858's Avatar
AudiWorld Expert
Default hmm you've got a FMIC and you're pinging still? that's no good.
have you checked your plugs to make sure they're in good condition? You're hearing the car ping regularly?
Old Jun 4, 2003 | 10:47 AM
Default it only pings under load at over 0.8 bar of boost.
i definitely need to check the spark plugs.
Old Jun 4, 2003 | 10:50 AM
paul_858's Avatar
AudiWorld Expert
Default have you replaced the plugs at all? and is the pinging consistant from tank to tank?
reason why I ask is there are a lot of people running the X chip and most don't have continuing issues with pinging. The chip is designed to retard timing so that the car doesn't ping. Actually the factory car does that too. make sure you're running a minimum of 91 octane fuel and make sure you're not going to a generic gas station. Running 100 octane won't hurt the car, just your pocket book..
Old Jun 4, 2003 | 10:56 AM
Default only occassionally pings since i got the x-chip. i always run chevron/shell/76 91 octane.
i'll check the plugs. should i go to a colder plug?
Old Jun 4, 2003 | 11:01 AM
kenny (dremel)'s Avatar
i thought with the X you had to run 93??
Audi2ptzero's Avatar
Elder Member
Default Yes, if your getting ping still on the 91 you want to put in
1 step colder plugs.
Old Jun 4, 2003 | 11:03 AM
any recommendations on which plugs to get? thanks.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 4, 2003 | 11:04 AM
x-chip was supposedly tuned on 91 octane.
Old Jun 4, 2003 | 11:12 AM
Silver Streakin''s Avatar
Member
Default yes. it'll kill your cat. that program is forcing the engine to dump the extra octane.
you should only be running 91-93. some say it takes advantage of up to 95-96, but after running 93 and 100 octane on the dyno with the X chip - it provided no change in total power.
