Are these spots okay for grounding ....
Old Jun 4, 2003 | 01:02 PM
a4tay's Avatar
New Member
Default Are these spots okay for grounding ....
<center><img src="http://pictureposter.audiworld.com/46215/g1.jpg"></center><p>
the is for the xenon kit. The place is the airbox to the chasis
a4tay's Avatar
New Member
Default 2nd spot
<center><img src="http://pictureposter.audiworld.com/46215/g2.jpg"></center><p>
Old Jun 4, 2003 | 01:03 PM
audimods's Avatar
no need to ground. just use the stock wiring.
Old Jun 4, 2003 | 01:04 PM
quattrofrog's Avatar
Senior Member
Default BROWN wires are GROUND
use your stock headlight wiring.
a4tay's Avatar
New Member
I was told that the stock wiring/switch could go bad with time, so better to do the relay.
Old Jun 4, 2003 | 01:05 PM
a4tay's Avatar
New Member
are these spots safe, if I keep them there for now?
Old Jun 4, 2003 | 01:08 PM
Senior Member
Default I wouldnt use your ABS as a ground, that could be bad.
Ground it to the body/frame if possible.
Old Jun 4, 2003 | 01:23 PM
a4tay's Avatar
New Member
yes
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 4, 2003 | 02:21 PM
audimods's Avatar
agreed. of course relays are safest bet. the audi wiring/switch is fine for these 35w vs 55 and up.
Old Jun 4, 2003 | 03:28 PM
chipstar-32's Avatar
Elder Member
ygm
