Does the dealer perform a wheel aligmnet under the warranty if you put custom suspension and wheels?
Old Jun 4, 2003 | 02:42 PM
MikeFliggity's Avatar
Member
kennyc's Avatar
doubtful
Old Jun 4, 2003 | 02:46 PM
Member
Do you have any idea how much they might charge?
Old Jun 4, 2003 | 02:48 PM
ex-quattro PETE's Avatar
AudiWorld Expert
lol... that's like asking a dealer to give you a free TT BPV after you chip your car.
Old Jun 4, 2003 | 02:49 PM
kennyc's Avatar
depends on the equipment they have... my guess is around $60.
Old Jun 4, 2003 | 03:07 PM
Sal R.'s Avatar
Default Technically...no. However, if the dealership is nice...
...they MIGHT do it for you.
My dealership was kind enough to straighten out my alignment during my last scheduled service maintainence. Keep in mind that I DID NOT ask them to do it seeing that it was because of my aftermarket suspension.
Old Jun 4, 2003 | 03:08 PM
Mat Indukts Lambos's Avatar
Banned
Default If you have bad ball joints on your tie rod ends, yes. More....
Reason being, Audi has had several problems with them, and it's likely that they would be bad regardless of your suspension & wheels. You should be able to get new tie rod ends and a 4 wheel alignment under warranty in this situation, but the dealer can also require that you put on stock wheels for the alignment. This is primarily due to the CYA factor, dealer doesn't want to be responsible for scratching your wheels, and may not have the equipment to do anything larger that 17" wheels.
It'd also help to tip the tech ;-)
Old Jun 4, 2003 | 03:13 PM
Member
Default YeaH, i'll probably just ask them to check it out and see if i need one.
Hopefully they'll do it under the warranty and if not i guess I will have to pay for it. Do you know how much it might cost?
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 4, 2003 | 03:24 PM
oatzel's Avatar
Elder Member
I was quoted $230. (2 hours labor). i went elsewhere
Sal R.'s Avatar
Default Shouldn't cost more than ~100 TOPS as it's a dealer.
I bought a lifetime alignment from a local shop for as long as I own the car ~150. They normally charged ~60 per alignment. Paid for itself after the third time. They did a good job even w/ the CCP upper control arm links I installed.
With that in mind, I get an alignment every couple of months. No sense in wearing out my S03's.
