WHOOHOO...FINALLY my tach reads correctly...thanks to all that helped...im soo happy now...
Old Jun 4, 2003 | 06:56 PM
Howie Feltersnatch's Avatar
Member
Default WHOOHOO...FINALLY my tach reads correctly...thanks to all that helped...im soo happy now...
finally my problem is solved...josh(wishbone) and chris(planetman) via telephone...helped me recode my tach so that it reads proper...this car is like night and day now that i am almost 2 grand lower on the tach then where i previously thought...thank god for audiworld!!!!
-justin
Old Jun 4, 2003 | 06:59 PM
ex-quattro PETE's Avatar
AudiWorld Expert
so the cluster was coded incorrectly?
Old Jun 4, 2003 | 07:03 PM
Blip's Avatar
Member
No problem enjoy
Old Jun 4, 2003 | 07:07 PM
coocoomike's Avatar
glad you got it worked ot!
Old Jun 4, 2003 | 07:14 PM
Member
ya..now i gotta figure out why.....
Old Jun 4, 2003 | 07:20 PM
Blip's Avatar
Member
Default I found the info....read down a little
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
Change Language Displayed:
[Select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 04
The available languages are :
00001 - German
00002 - English
00003 - French
00004 - Italian
00005 - Spanish
00006 - Portuguese
[Save]
Resetting Service Reminder Intervals:
Old Jun 4, 2003 | 07:22 PM
AudiWorld Expert
previous owner of his car probably screwed with the VAG-COM.
Old Jun 4, 2003 | 11:34 PM
Member
does that mean i can undo the sensor for my washer fluid? that things been on for months
 Pouria Savadkouei
 Michael S. Palmer
OCA::DIY Motorsports
Jan 28, 2014 06:40 PM
ImAwesome
Jan 9, 2007 03:45 AM
[KRAFTIG]
Nov 17, 2006 06:21 PM
applejacks
Jul 3, 2005 08:42 PM
SilverToronto
Sep 13, 2002 10:23 AM
