Please help... headlights don't work...
Old Jun 4, 2003 | 07:12 PM
BrooklynA4's Avatar
New Member
Default Please help... headlights don't work...
on sunday both of my headlights stoped working. After doing a search on AW I figured it was the combination switch a pretty common problem. A buddy of mine has a shop and he happened to have whole steering column from a 98 (BTW mine is a early 99) A4 so I tried that switch on my car and the headlights still no go.
Can it be something else? or with my luck that switch is also bad?
TIA
Old Jun 4, 2003 | 07:15 PM
A4QuattroVT's Avatar
Member
Default do just specific beams not work.. or all of it? happened to me
i replaced the two h7 low beams and they work fine now
Old Jun 4, 2003 | 07:16 PM
fussball.biturbo's Avatar
Default well, I am hoping you checked the fuse, and relay?
otherwise, it could be bulbs... but that is extremely unlikely that both would burn out...
BrooklynA4's Avatar
New Member
The high beams only work when I hold them and the foglights buttons don't light up
Old Jun 4, 2003 | 07:17 PM
BrooklynA4's Avatar
New Member
I did check the fuses first thing
Old Jun 4, 2003 | 07:19 PM
Member
I had both mine burn out one, then about 1 second went by, then the other
f3d's Avatar
f3d
AudiWorld Uber User
Default mein went a while ago...
$115 for the switch from audi...requires removal of wheel/airbag. Its a ****ty design to begin with and the use of ricer bulbs greatly accelerates this problem(if youve been using them..) Problem stems from the switch heating up and melting. Dunno about the jetta switch, but I have the same year as you and had this problem too. If your high beams work when using the switch in a fashion as to "flash" another driver, but not when turned to the high beam - on position then its the switch. Hope this helps a bit.
Old Jun 4, 2003 | 09:20 PM
Niko_F's Avatar
sounds like its the switch
 Pouria Savadkouei
 Michael S. Palmer
Hit Man
Oct 6, 2004 08:57 AM
2.8beast
Sep 30, 2003 11:51 AM
tshaw
Aug 23, 2003 07:52 AM
Joey T
Jun 12, 2003 08:51 AM
LilMex
Jan 16, 2003 06:30 AM
