Stoptech Stainless Steel Brake Lines - Installed Today!
As usual Louie was absolutley meticulous ensuring absolutley no air in the lines - the whole system was bled and flushed and new Dot 6 High Performance fluid used.
Pedal Feel is definately improved with the SS lines - the stock sponginess is completley gone and the pedal 'feel' is much firmer. Whilst some of this is attributable to the 'bleed and flush' - most of it is due to the near zero flex in the new lines.
You can see in the pics below the high quality construction of the lines - including a full clear plastic sheath over the braid to protect it from damage and rubber end coverings. Conveniently the lines are tagged with yellow rubber bands as DOT approved - for any boyz in blue who see fit to poke their noses under the wheel arches.
This is the front line installed. (1 per side)
<img src="http://www.users.bigpond.net.au/worx/sslines2.jpg">
This is the rear 2 lines installed (2 per side)
<img src="http://www.users.bigpond.net.au/worx/sslines1.jpg">
A big thank-you to Louie and the Boyz at Euroclass for the great work - thanx guys!
