Potentially Big Problems with my car as a result of a puddle last night...
Old Jun 5, 2003 | 06:19 AM
ByeByeA4 (AdamA418T)'s Avatar
New Member
Default Potentially Big Problems with my car as a result of a puddle last night...
While crusing the streets last night in a rain storm, I came accross a large puddle that had formed at the bottom of an overpass. I took it easy through the puddle but when I was in it, my car started to bog and cough. It stalled, rolled for a bit and now it will not start!
I removed my custom cold air extention a few months ago but still have the LLTek intake kit with S4 vented wheel liners on both sides. I think I took in some water through the intake! What do I do? How can I tell what has happened? I think I will replace my air box before I take it to Audi.
Any Ideas???
Old Jun 5, 2003 | 06:26 AM
Silver Streakin''s Avatar
Member
sand should dry it out
Old Jun 5, 2003 | 06:34 AM
New Member
How does that work? What do I do?
Old Jun 5, 2003 | 06:46 AM
markbradford's Avatar
Rest In Peace
LOL!!!!!!!!!
Old Jun 5, 2003 | 06:47 AM
Rest In Peace
Default Start with reading this thread...
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1567770.phtml">https://forums.audiworld.com/a4/msgs/1567770.phtml</a</li></ul>
Old Jun 5, 2003 | 06:49 AM
#169's Avatar
Junior Member
priceless
Old Jun 5, 2003 | 06:52 AM
Blake(w/ 16g)'s Avatar
Elder Member
adam please tell us that you understand streakin is joking about that :-D
Old Jun 5, 2003 | 07:05 AM
New Member
So what do I do?
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 5, 2003 | 07:13 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default Well, either water got somewhere it shouldn't be and it'll eventually dry out...
in which case the car will start...someday, OR water got into the engine, in which case, the engine is fvcked. If you're using aftermarket intake kits...you need to be careful. Once water gets to the filter/cone, it can easily work it's way into the engine. With the stock airbox assembly, a little water can get pulled through the intake opening, but it won't readily work it's way into the engine.
Old Jun 5, 2003 | 07:14 AM
Rest In Peace
Default How deep was the puddle? How fast did you drive through it?
Did you try starting it this morning? Does the filter element feel wet? Is there any residual water in the U pipe?
