10v I-5 Turbo IM with Secondary Injectors and ECU
Old Oct 25, 2001 | 01:15 PM
audifreakjim's Avatar
25 Year Member
Default 10v I-5 Turbo IM with Secondary Injectors and ECU
Great for a turbo conversion on your 80/90, 4000, CGT, or if you just need to add more fuel to your system. This system makes it possible to put a turbo engine in your car without nightmare of swapping in the turbo fuel system. You simply use your stock CIS system, then when you need more fuel under boost, the secondary injectors kick in. I have run 20 psi through this system with no problems. Depending on your intercooler and ignition system, you may see different results. You will need a computer, preferably a laptop, running Windows 9x to program the ECU. All of these items are included in the price: Intake manifold with 5 secondary EFI injectors, fuel rail, fuel regulator, some fuel lines if you want them, intercooler with the small hose output, ECU with settings, and second fuel pump. I can sell just the IM and ECU together if you are not interested in the other stuff. I am selling this stuff because I am going to a full EFI system with a header. All of it together for $650.<ul><li><a href="http://www.geocities.com/jeg1976/car_home.html">http://www.geocities.com/jeg1976/car_home.html</a</li></ul>
Old Oct 30, 2001 | 07:51 AM
CanyonBlaster's Avatar
Default Re: 10v I-5 Turbo IM with Secondary Injectors and ECU
<center><img src="http://pictureposter.audiworld.com/13040/4000_4.jpg"></center><p>Sweet car! Are you in the Denver area? You should come out to the track.
audifreakjim
May 30, 2005 11:50 AM
AEGA4
Oct 9, 2002 02:31 PM
BigMouse
Dec 8, 2001 06:37 PM
audifreakjim
Oct 25, 2001 01:17 PM
CharlieGSanD
Mar 21, 2001 10:57 AM
