Interior Light
Old Oct 25, 2001 | 05:41 PM
AudiSport4000's Avatar
Default Interior Light
I thought I had all of my lighting problems fixed, obviously I was wrong. I fixed the wiring harness for my headlight. But, when i was cleaning out my car about 3 weeks ago, my interior light(right above the drivers door) would only come on if it was in the actual "on" position. It doesnt come on when i have it set at the "door ajar" setting. So whenever I open up my door, the light no longer comes on. Any idea whats causing this? Any info helps here! heh
Mike
85 4000S
Old Oct 25, 2001 | 09:11 PM
JeromeS.'s Avatar
Member
Default Check other doors, and replace door buttons
also, just replace the assembly ~easy~..find them at the yard cheap.
Old Oct 26, 2001 | 03:58 PM
rocketaudi's Avatar
had the same prob, never fixed it. not helpful but at least you wont feel alone now.
Old Oct 26, 2001 | 05:17 PM
Chris in VA's Avatar
Junior Member
Default Re: Interior Light
My experience with Audi electricals is bad wiring. I would first check the door switch which tends to corrode after a while. If you're not getting voltage to the switch, the wires from the car to the door might have pinched in half.
martyn brooks
Sep 30, 2014 05:24 AM
dimmer2
Feb 14, 2009 10:37 AM
babar760
Dec 18, 2008 08:12 PM
pianogrg3
Jul 26, 2004 04:27 AM
XcellR8edAudi
9
Jun 30, 2004 09:48 PM
