Lost: Spark for a 4ks, Reward offered
Testing using the Bentley indicates a possible failed Hall Sensor controller but swapping in a known good unit is no help. Swapping in a known good Knock Sensor controller also has no effect. Wiring checks out. Testing at the coil taps 1/15 shows that during cranking there is exactly one discharge of the coil, after that the ground is constant.
TIA
Keith
If this is what you call a Hall Sensor, then disregard.
