question about disassemling plastic center console on a 1986 4000s
Old Nov 3, 2001 | 03:58 PM
smurfy's Avatar
New Member
Default question about disassemling plastic center console on a 1986 4000s
i raised a question earlier about problems with my reverse lights, and was advised by the helpful contributors on this board to check the electronic switch, which is located (as I've been told) inside the plastic center console housing, underneath the shifter (its an automatic transmission). However, I am struggling to figure out how to disassemble the plastic casing without breaking the plastic... is this mounted by screws? should i dissassemble the shifting **** before i attempt this? does anyone have any tips as to how this can be done most effectively?
would appreciate any help!
btw, excellent forum!
Old Nov 3, 2001 | 04:48 PM
AudiSport4000's Avatar
Default Yes
As I can remember, there are screws that take apart the plastic console, look at the bottom near the carpet and hadbrake lever, there should be a couple there, and the others are up near the vents in the middle of the console. As for the gearshift,I dunno, Ive tried to get mine off, but im pretty weak and pathetic, hehe. HTH
Mike 85 4000S
Old Nov 3, 2001 | 05:14 PM
Evol's Avatar
Default Re: question about disassemling plastic center console on a 1986 4000s
remove the two screws in front of the hand brake, then remove the ashtray and remove the two screws on the front edge of the cover. unscrew the set screw for the shifter ****. That will pretty much take care of it.
Old Nov 4, 2001 | 11:18 AM
dc2002's Avatar
Default THE REVERSE LIGHT SWITCH IS SCREWED INTO THE TRANNY FOLKS- MY BAD!! DIDN'T SEE AUTO TRANS :)
It is accessible from the passenger side of the vehicle either through the wheel well or you need to crawl under the car on the passenger side. The switch is about $20 and takes about 10-15 minutes to change.
084 941 521
BACK UP LIGHT SWITCH
80-87 4000 4 Cyl.
80-81 4000 5 Cyl.
82-83 4000 Diesel
82-83 4000 Turbo Diesel
84-87 4000 Quattro
courtesy of www.thepartsconnection.com<ul><li><a href="http://www.thepartsconnection.com">http://www.thepartsconnection.com</a</li></ul>
Old Nov 4, 2001 | 06:46 PM
1hot4000s's Avatar
New Member
U gotta take off all the Heater switches pull them off then pull of the heater cover lil plastic cover with the heat and stuff then youll find screws i broke mine cause i couldnt find them
Old Nov 4, 2001 | 07:44 PM
Evol's Avatar
not on a automatic.
Old Nov 5, 2001 | 07:27 AM
dB's Avatar
dB
Did you check the wires in the trunk first??? They usually break and kill the lights.
Old Nov 5, 2001 | 10:09 AM
Chris in VA's Avatar
Junior Member
Default I'll second that
Where the wires go into the trunk at the lid arms might be broken. Mine were severed in half, and the brake lights would only work when the wires happened to make contact. This also happens at the doors too.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 5, 2001 | 05:35 PM
smurfy's Avatar
New Member
Default so the consensus is that the switch is accessed from the interior
of the cabin? at the center console? and NOT accessed from the exterior at the bottom of the car right?
Old Nov 5, 2001 | 06:05 PM
Evol's Avatar
Correct, do you have a bentley?
Calvin Craig
Dec 26, 2008 06:17 AM
jkcizbck
May 27, 2007 04:11 PM
Imola Ghost
Mar 18, 2006 06:45 AM
MelloYelloS4:Indkted
Feb 1, 2003 08:33 PM
Satypos
Apr 11, 2002 06:46 PM
