coolant light
Old Nov 5, 2001 | 02:07 PM
mgs1's Avatar
Default coolant light
The coolant warning light has begun to flash whenever I take a corner or accelerate moderately hard. The fluid level and concentration is fine and there are no leaks. Any ideas?
Mark
'87 4KQ
Old Nov 5, 2001 | 02:30 PM
BoraSport's Avatar
New Member
Default I have the same problem!
They have told me that the coolent level must be low or the sensor is bad. I have not had a chance to attempt to fix the sensor but I have verified my coolent level is correct.
My car is an '84 4KqCS
Old Nov 5, 2001 | 03:32 PM
1hot4000s's Avatar
New Member
Default Re: coolant light
i used too have that problem ill ask my dad what it was and get back too ya
Old Nov 5, 2001 | 06:02 PM
Evol's Avatar
Probably a bad water sensor in the bottom of the water container
Old Nov 6, 2001 | 09:38 AM
dc2002's Avatar
I had the same issue, and here is what I did when I finally got sick and tired of looking at the flashing light:
Unplug the coolant sensor and see if that has any effect. Hot wire the plug and, again, see if that has any effect. If not, then replace the temp sender on the top of the coolant pipe that the upper rad hose connects to. That should lick the problem
Old Nov 7, 2001 | 06:14 AM
Jamie '87 CGT's Avatar
New Member
Default Re: I have the same problem!
I had the same problem, I unscrewed the sensor a little to allow air to escape, and let out any possible air bubbles, that worked for awhile, but just this week the darn thing started doing it again, i will post it, if i decide to go get a new sensor, if that fixes it for good, its pretty aggrevating,JP
Rune Korneliussen
Apr 16, 2013 01:04 PM
rjhavens1
12v V6 Discussion
Jan 16, 2010 11:22 AM
Canon
Apr 4, 2009 05:42 PM
Visti
Canadian Discussion
Oct 20, 2008 04:53 PM
Seanism (clone510)
Nov 8, 2003 01:32 PM
