Ticking?
Old Nov 7, 2001 | 07:53 PM
1hot4000s's Avatar
New Member
Default Ticking?
i think its my lifters but im not sure...is ther anything i can do to get rid of it? and does it hurt my car if i drive it hard with this ticking?
Thx, Mike
Old Nov 7, 2001 | 08:10 PM
Evol's Avatar
Default Try running 1/2 quart of ATF right before your next oil change
It cleans out the oil passages on the lifters. It quieted my down a bit.
Old Nov 7, 2001 | 08:16 PM
Chris in VA's Avatar
Junior Member
Default Tikka Tikka Tikka
Been there, done that. You don't need lifters.
Ticking could be one of two things. First, and the most common, is the lifters. Over time they can't hold pressure after the engine shuts off, and they bleed down. The fix? Get a genuine Audi/Bosch oil filter and fresh oil. Serious. These have a special valve in there that prevents oil from draining out of your engine. Many people have changed their lifters thinking that would cure it. Oops. I used Fram and Purolator filters for a while, and man did that machine tick!
Second, the 4kq's have a secondary vacuum pump to 'boost' the power of the brake booster when you theoretically brake while hitting the gas and the manifold doesn't have adequate vacuum. Does this ever happen? NOOO! So, to check this special sort of tick, you need to locate the big silver round thing on the right side (driver) of the engine, on top. Has a vacuum hose coming out of it. Take a screwdriver, hold it to your ear while pressing on the unit. Loud? If so, there is a 3" steel rod inside that follows one of the cams and acts as a solid lifter for the pump. This also tends to wear, causing a loud 'clack'. With the advice of an Audi guru a while back, I removed that rod with no adverse effects. It sits in my toolbox, rusting away.
So, follow these steps and see if it helps you.
Chris
86 4kq
200k miles
Old Nov 7, 2001 | 09:01 PM
1hot4000s's Avatar
New Member
Default Re: Tikka Tikka Tikka
ahhhhh thx...im gonna get a oil change....and then ill try that Vacuum pump thingy....
thx man
Old Nov 7, 2001 | 09:02 PM
1hot4000s's Avatar
New Member
Default Re: Try running 1/2 quart of ATF right before your next oil change
whats ATF?
Old Nov 7, 2001 | 10:45 PM
SteveAngry's Avatar
Default Automatic Transmission Fluid...
It's an old mechanics trick. Put a little in just before an oil change. ATF has alot of detergents, etc and will clean up alot of the gunk...
Works pretty good. However some times lifters are just too far gone and the only way to get them to shut up is to replace them...
Steve
Michigan
Old Nov 8, 2001 | 08:05 PM
1hot4000s's Avatar
New Member
Default Re: Automatic Transmission Fluid...
ok thx...that cant hurt my engine?
Old Nov 8, 2001 | 10:54 PM
SteveAngry's Avatar
Default Well...
you don't want to run around with it in there for long...
If you want to play it safe, just pour some in and idle the car for awhile just before an oil change...
Let the oil cool, then change the oil...
Steve
Michigan
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 9, 2004 | 09:51 PM
Audi Junkie's Avatar
Community Builder
Ummm, ATF has less additives and is a SAE 20 oil.
Old Sep 17, 2004 | 06:58 PM
Community Builder
Default Bad idea. ATF has less detergents. Old-timer stupidity.
<ul><li><a href="http://auto-rx.com">http://auto-rx.com</a</li></ul>
mz500
Feb 6, 2018 02:59 AM
audi-driver1126
27
May 23, 2012 03:59 PM
Bob Loblaw
18
Jul 9, 2005 10:24 AM
bl98263
Nov 5, 2004 03:03 PM
VonK :: Retired
May 5, 2001 10:26 AM
