It is alive. The 86 CGT now breaths Fire. Not real fire but you know what I mean.
The car ran, very loud, I believe there was this loud and fast ticking from the valves right? but it went away. The smoke kept coming from what is probally that dirty ground cable, I sprayed it with wd 40 to help for the meanwhile. The dash gauges did not light up.
I check one of the fuses and it was held in with aluminum foil. The connects were bent or something, so now I need to either get a new fuse tray or rig it up. I am not sure I will be able to solder in wires to make a fuse connect. Can anyone help?
