Won't Start!!!
all you have to do is set the flywheel to TDC
and line up the cam sprocket with the valve cover
(on the back side of the cam sprocket)
you will see a little window by the top of the valve cover.
this is to set the cam timing...
you are lucky the non turbos aren't interference..
oh yeah when checking for TDC on the crank, look in the bellhousing..
but the best way to verify the crank is set to TDC
is take out the #1 plug and get a long screwdriver
and you'll feel the piston come up and top out.
this is TDC (top dead center)
HTH!
rich
'86 4kq
