Timing???
Old Nov 11, 2001 | 08:18 AM
Tylerb929's Avatar
New Member
Default Timing???
I am trying to set my timing, after replacing my water pump(already messed up timing during this). This car is new to me and I really need some one to walk me through this. How do I set the TDC, where is the TDC window, what do i line up, a complete walk through would be helpful but answering any of these questions would be good. Thanks for your help.
Old Nov 11, 2001 | 02:22 PM
Dwight V.'s Avatar
Member
Default A little help
Man, you have GOT to get at least a Haynes manual!
There should be some timing marks on the flywheel. There is a window in the bellhousing for you to see them. Easiest way to find TDC though is remove the spark plug and insert a screwdriver into the cylinder. When the piston comes up to the top the tool will no longer move up and will start to go down. BE VERY CAREFUL not to allow the tool or whatever you use to damage the piston or hit the bore while doing this! You can then determine the proper location for the cam by the position of the lobes and the valves that are open (#1 obviously will have both valves fully closed). There is probably a mark on the backside of the cam pulley that should be equal to the valve cover gasket mounting surface when properly positioned.
Take this all with a little salt as I did this over a year ago and my car no longer had markings on anything but the cam thanks to the jigsaw puzzle of parts I used.
dlander-82
Oct 8, 2013 02:47 AM
Pepper4177
Jun 15, 2009 08:53 AM
CarIsScrewed
Audi 100 / A6 (C4 Platform)
Nov 24, 2007 03:26 PM
6 audis
May 9, 2007 05:29 AM
lotus7racer
Nov 14, 2001 10:09 AM
