The living Coupe GT and its new problems. What is all this stuff?
What is
The two pin sensor on the back of the head and does it hook up to something? Oil?
What is the two wire device on the pass. side on the back of the valve cover? Under hood temp sensor?
What is that black wire that comes out of the same harness *** the starter wires but clips to the oil pan and has a rubber boot and a eyehole connector? Mine just hangs there.
Thanks in adavance to those that help. I will take you for a ride or run you over, your pick
Dave
two wire device on back of valve cover is for after run fan
the last wire dangling is for your oil temp gauge.
HTH!
rich
'86 4kq
the last wire dangling is for your oil temp gauge. Where is the Oil temp gauge?
