Steering shake
Old Nov 13, 2001 | 09:09 AM
TCP's Avatar
TCP
New Member
Default Steering shake
my 87 4000s has a minor oscillation that can sometimes be felt through the steering wheel from about 55-65mph. this doesn't happen all the time and i don't think it's a wheel balance problem in that it disappears above 65 and has no effect before 55 and doesn't always happen. it seems to be more prevailent while accelerating through that range than slowing through it. i realize all vehicles have some oscillation frequencies and it's not the newest but it has low milage and everything else works perfectly. Any info or thoughts are, as always, appreciated. t
Old Nov 13, 2001 | 11:53 AM
Chris in VA's Avatar
Junior Member
Default Re: Steering shake
Could be any number of things really. Loose bearings, bent rim, warped tire, out of balance, warped rotor...etc etc. I had a badly bent rim on my GTI when I first bought it. The shake would start around 55 and gradually smooth out over 65-70. Take your car to a place that has one of those 'RoadForce' wheel balancers that apply force to the TIRE to check for a bent rim or bad tire.
Old Nov 14, 2001 | 05:55 AM
Jamie '87 CGT's Avatar
New Member
I have the same problem, not balance, nor bent rim, so im gonna try the control arm bushings, and/or possibly the upper strut mounts is what im thinking,but if you get your fixed let me know,JP
Old Nov 14, 2001 | 06:46 PM
Junior Member
Default Control arms
Mine were kaput, but they didn't cause the car to shake like that. I just got a woozy steering feel with some unwanted lane-change effects.
SamRS7
Wheels & Tires Discussion
17
Sep 16, 2020 02:29 PM
beltway
May 7, 2008 06:51 AM
AudiS4inCT
Feb 12, 2003 02:15 PM
bgaTTesjr
Nov 21, 2000 08:32 AM
