2.3 swap into a 4000csq
Britt
There are a few little weird things to deal with. The vacuum pump goes goodbye, and it isn't missed. I think the rubber plug on one of the intake fittings is the same size; just plug it and let the line run straight to the booster. Use your intake system. The injector sleeves have to be replaced with yours (they are threaded into the head; remove with an allen wrench). Pipe fitting on the back of the block has to be swapped around. The block is drilled for all the brackets you'll have to re-use, no problem there. Oil pan and valve cover may need to be used from your old engine (I used a 5k motor, and they were different). Not much else to it. If you get an automatic motor you'll have to removed the bushing in the end of the crankshaft and replace with a pilot bearing. This is not a fun job for the home mechanic, but it can be done.
Engine comes out from the BOTTOM with the trans attached. There are other ways to do it, but you'll beat yourself up trying. Some guys cheat and cut the rad support off the car, but I prefer not to chop my car apart to R&R an engine.
Safety note: these motors are ungawdly heavy! Don't try to move one yourself, or you'll be at the chiropractor shortly afterward.
Britt
Yes, I feel it is a worthy swap, but only if you simply swap engines. If you have to rebuild the donor motor it is a poor value, as the 5cyl is an expensive one to rebuild. Used engines are generally cheap for these, and anything around 100,000 miles should be fine with fresh seals, gaskets and lifters.
I would suspect the quatt is only slightly different from the CGT as the cars are the same from the bellhousing forward. I would think the engine should still come out from the bottom. The steering linkage gets in the way of a top removal and it is really difficult to maneauver it in the small amount of space left.
I also think you'll still get smoked by the VR6's. They are simply fast.
