Need help
Old Nov 17, 2001 | 10:02 PM
Fat_Joe's Avatar
New Member
Default Need help
Hey everyone. I am having some trouble with my Audi so I thought mabe you could help me out a little. When I first got my Audi(87 4000S with the 1.8 liter and auto), it idled/started very poorly. I took a look at the Fuel injection system and found that it had been messed with quite a bit. I took off the throttle body and found the idle switch(on the bottom) had been purposely disconnected and the idle screw was moved so that the valves on the throttle body are slightly open. I re-adjusted the screw to proper specs. I also checked the fuel mixture at the fuel distributer by doing the milliamp test and it is fine. Anyway after all of this, the idle is a little better but not where I would like it to be. When it is cold and I push down on the gas pedal and then let go(throwing the idle switch), the engine almost dies. Also it has hesitation when cold too. What i think is happening is that the idle speed motor is kicking in a little slow, but i dont want to replace it until I am sure. Is there a way to test the idle speed motor or any other diagnostic tests that you know of that I can do to help find the problem? Any help would be appreciated. Thanks
Old Nov 17, 2001 | 10:51 PM
1hot4000s's Avatar
New Member
Default Re: Need help
as for starting.........my car had no presure in the fuel line so this audi "no all" said it was my seperate release valve....got it replaced fuel pressure up and bam its perfect......as for your idle problem arnt the 4000 s digitally idle controlled? i think you can hook up a diag test too it.......hope that helps ya.
mike
Old Nov 18, 2001 | 12:32 PM
Chris in VA's Avatar
Junior Member
Not sure what you mean by the 'idle speed motor'. These have an ISV which is a rotary valve controlling the amount of airflow to bypass the intake, regulating the idle characteristics. These things are a constand PITA to all VW/AUDI guys. They stick all the time.
Most of these cars tend to be cold blooded. My GTI and 4kq both act the same way when started. I would first replace all vacuum hoses and see how that helps.
Old Nov 18, 2001 | 01:02 PM
Fat_Joe's Avatar
New Member
Yep. Sorry for the incorrect name. I was referring to the ISV. I heard they stick too so I cleaned it out in the solvent tank and unpluged it, but it didn't seem to help very much. I might just replace it. Do you know exactly what models this part is on because I am having a hard time finding an Audi 4000 with the same fuel injection system as mine in the junk yards and I would like to pull one off. Are there any VWs with the ISV? If replacing it does not help, I will my car to my friends shop and test the vaccum pressure and make sure it's up to specs.
Old Nov 19, 2001 | 05:52 AM
Junior Member
Well, it probably doesn't work any more because you put it in solvent. There's an electrical motor in there. Zap.
To get a new 'used' one, call Shokan at 1800 ALL AUDI in NY state. They'll have one.
Old Nov 19, 2001 | 07:17 PM
Fat_Joe's Avatar
New Member
Thanks fot the number. Just for the record I did not *submerge* it in solvent. I was very careful not to get solvent in the electric motor. I may do stupid things sometimes but I am not THAT dumb.
Jcampbell3
Q5/SQ5 MKI (8R) Discussion
15
Sep 25, 2015 01:23 PM
fotograf
Aug 2, 2009 07:18 PM
searchin99
Inline-5 Discussion
Jan 16, 2009 05:19 PM
Black01S4WI
23
Oct 19, 2006 07:15 AM
