Subframe bushings?
Old Nov 18, 2001 | 06:33 PM
86 Gt commem.'s Avatar
Default Subframe bushings?
Hey all,
I own an 86 coupe gt that needs a little work. While preparing to put new front struts in, I found a the front left spring was broken and the A-arm bushings that hook the suspension to the frame are completly shot. The cars only got 101,000 on it. any one else have to deal with this? Anyone know were to get better replacement bushings?
Old Nov 19, 2001 | 02:30 AM
Dwight V.'s Avatar
Member
Default Those aren't subframe bushings
Control arm bushings are different. Subframe bushings are the one that connect the subframe assy to the car frame. This will keep you from ordering the wrong thing.
I think Blau sells urethane bushings. I've also heard of Delrin bushings but don't know anything about them. I just replaced mine with the stock stuff; I figure it they last 100k+ miles, they can't be too bad!
I think I've heard of one broken spring before, but it's actually pretty odd. If you replace it, best to do it in pairs. You can just buy used ones that way and save quite a bit of $.
Old Nov 19, 2001 | 05:45 AM
Chris in VA's Avatar
Junior Member
Default Clarification needed
He might be referring to the bushings connecting the a-arms to the body. The control arms are the pivots in the arms themselves. I had to replace those 2 years ago on my 4kq. My tranny mounts were also broken.
Old Nov 19, 2001 | 01:00 PM
Default Re: Clarification needed
Yes, the bushings that connect the a-arms to the body. There is a tremendous amount of play in the bushings. I think it may even be responsible for the broken spring.
Old Nov 23, 2001 | 09:13 PM
audinutt's Avatar
25 Year Member
the A-Arms connect to the subframe.
the subframe connects to the body in 4 places.
if your control arm bushings are shot then
you are probably in need of balljoints and tie rods too.
i just got done upgrading my 4kq to 90q parts.
(bigger ball joints and ABS ) ABS is not wired up just yet...
but this is an ongoing project...
you get bigger wheel bearings and a slightly wider track too.
enough ramblings..
order new tierods and balljoints and while your at it might as well get strut mounts (upper)
the difference in the car will be night and day.
go to www.bimmerparts.com tie rods are like $15 for the end and i paid around $100 for both front complete rods.
HTH!
rich
'86 4kq
J450NP13
Oct 14, 2017 09:04 AM
LunaTTic
Nov 24, 2008 10:52 AM
86coupe
9
May 28, 2007 02:19 PM
liquidfu22
23
Oct 27, 2004 11:34 AM
SCarGo02
10
Sep 21, 2004 09:30 PM
