Suggestions Welcome on my CGT
So now you all know my problems and suggestions would be appreciated..
Thanks
Change the digital dash to analog. You can surely get everything you need at the U-Pull-It out of any 4kq or CGT. Or, you might try taking the dead cluster to a speedometer shop, they can sometimes fix them if it's just bad solder joints. NEVER go to the dealer for anything unless you absolutely have to!
Cat converter? Kind of odd to need one of those, I'm curious why. If it's clogged, just take it off and ram the guts out of it and reinstall. If it won't pass emissions, that's another story.
Leaking head gasket is probably just annoying and messy, if it's just damp and not gushing I wouldn't worry about it. Run 20-50 oil to slow it down.
Frt struts, get some Boge Turbogas, they are not expensive and work very well, I run them in my car.
Good luck!
