'86 4KQ Motor swappie.....
Old Nov 25, 2001 | 06:26 PM
Pawl-X's Avatar
New Member
Default '86 4KQ Motor swappie.....
I have an '87 5000 FWD with an auto. I am planning on swappin' the motor from it into my '86 4000 Quattro. Can someone give me insight into what will be needed to acomplish this?
?'s I have:
Can I use the fly-wheel off my orig. 4000Q motor?
Do I need to change the ECU? (since the '87 has a knock sensor and 10:1 compression)
Does anything have to be done with the exhaust?
If someone could help with a complete parts list, it would be most helpful.
Old Nov 26, 2001 | 03:12 AM
Dwight V.'s Avatar
Member
Default BTDT
It's pretty easy. Your specific Q's:
1) Yup, use your flywheel. You'll have to remove the bushing in the automatic crank's back end, which is tons of fun.
2) Nope, stock ECU works fine if you use the same injection. Knock sensor not usable without the newer ignition/distributor/brain box. Proper timing and 93 octane works fine for me.
3) Nope, uses same manifold already in your 4kq.
Between the two engines you should have everything you need. I thought I addressed this not too long ago but can't find the post...email me if you want and I can tell you the specifics. mxbreed@paonline.com
The Librarian
Audi Original "S" Cars
Jan 9, 2006 03:00 PM
OMP
Oct 3, 2005 12:21 AM
RedBelliedJet
May 2, 2005 05:52 AM
Crayfish
Quattro: Turbo / Ur / Sport
Jul 21, 2003 08:32 AM
Dr.quattro
May 29, 2003 10:30 PM
