Well, here she is!
Old Nov 28, 2001 | 06:55 PM
eMKay (BFLO)'s Avatar
AudiWorld Uber User
Default Well, here she is!
Not bad for $1300 eh?, paint needs a little work, no rust, no issues, the only thing that doesn't work is the AC.
<img src="http://pictureposter.audiworld.com/6695/4kside.jpg">
<img src="http://pictureposter.audiworld.com/6695/4krear.jpg">
<img src="http://pictureposter.audiworld.com/6695/4kinterior.jpg">
<img src="http://pictureposter.audiworld.com/6695/4kseat.jpg">
<img src="http://pictureposter.audiworld.com/6695/4kengine.jpg">
Old Nov 28, 2001 | 07:24 PM
AudiWorld Uber User
BTW, anyone know how to turn off the maintenance indicator?
Old Nov 28, 2001 | 08:13 PM
AudiSport4000's Avatar
Wow...very nice, love the seats
Old Nov 28, 2001 | 08:21 PM
Bernie's Avatar
25 Year Member
Default Answer inside...
I believe you refer to the 60k mile reset for the O2 sensor. You must remove the instrument cover, and on the back side, there is a small, square hole that you insert a screwdriver or other long, thin object to press a reset inside the instrument cluster. If this has never been done before (low mileage car), there may be a plastic "tooth" in the way, similar to a videotape erasure prevention tab. You will need ot desturctively remove this tab, then press the reset.
Nice car, late 87 by the quattro cloth. Too bad it's red, red is for hookers (JK!)
Old Nov 29, 2001 | 04:43 AM
dB's Avatar
dB
Default While your at it take out that whole O2 mechanism (i.e. the gear). Your odometer will thank you.
See previous posts.
Old Nov 29, 2001 | 06:23 AM
AudiWorld Uber User
Thanks!
Old Nov 29, 2001 | 02:44 PM
Chris in VA's Avatar
Junior Member
Default Aw man...
You SUCK! Sheesh...1300 bux for that. I paid 4000 for mine, and it's not as nice. Jeez...
Old Nov 29, 2001 | 05:42 PM
AudiWorld Uber User
Default I went on an extended drive tonight, odo is broke! Ha! Oh well...
It runs strong, and rides great, this car has had a lot of work done. I found new CV joints, what looks like newer shocks, good brakes, new (really cheap) tires. Things broke - AC, power mirror switch, radio is a complete POS (no biggie) and the paint is faded. There is one rust spot near the left rear window (the small one). I'm happy with this car, even if I have no clue how many miles are on it.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 30, 2001 | 06:47 AM
Evilclown's Avatar
AudiWorld Uber User
What gives with the A4? Why'd you sell it?
Old Nov 30, 2001 | 09:06 AM
Bernie's Avatar
25 Year Member
Default Radio and Power mirror switch...
Lots of folks have had good results by replacing the radios with either Kenwood or Blaupunkt units, either can be had with lighting that matches the instruments.
The power mirror switch is typically in need of cleaning. The switch is located so that people either get them wet with the window open, or spill their latte/soda/whatever in them. You can take it apart by removing the arm rest, and removing the switch housing from the it. Disassemble the switch (carefully, small parts!) clean all the contacts and lube, reassemble and it works fine. If not, you can get these at a junkyard for little or nothing, most Audis of this vintage had them.
Good luck!
