I used 20w50 all summer, is it too thick for the winter?
Old Dec 2, 2001 | 07:07 AM
Jeff Doble's Avatar
Junior Member
Default I used 20w50 all summer, is it too thick for the winter?
I'm wondering what oil to use for the upcoming winter?
Old Dec 2, 2001 | 07:43 AM
AudiSport4000's Avatar
I usually use 10w-30 for the winter-time
Old Dec 2, 2001 | 08:41 AM
Chris in VA's Avatar
Junior Member
Default Depends on your winter temps
Generally if it gets below freezing, you want at least 10/30. How hot does it get where you're at that you use 20/50?
Old Dec 2, 2001 | 03:36 PM
Jeff Doble's Avatar
Junior Member
Default Re: Depends on your winter temps
I live near Philly so summer temps can get up to 100°F or so but hardly ever do. The Audi manual recommends 20W50, but it seems too thick for winter use.
Old Dec 3, 2001 | 06:08 PM
Tylerb929's Avatar
New Member
Default problem is...
10w-30 makes the lifters noisey, and 20w-50 probably is too thick for winter. I'd say 10w-40 is a better choice.
Old Dec 3, 2001 | 06:22 PM
My lifters are never noisey, unless i let it get low on oil.
Old Dec 3, 2001 | 08:26 PM
Junior Member
Default Lifters
Are you using a genuine Bosch oil filter? If not, you'll get lifter noise. The genuine filters have this 'anti-drainback' valve built in, and the lifters actually have some oil to pump up with when you start the car. I had the usual tapping for quite a while with 'regular' filters until I switched. This is with 10/30.
A4wheelin
31
Nov 15, 2007 06:59 PM
max20V
13
May 12, 2005 07:36 AM
KC-Denver 20V
Oct 15, 2004 07:58 AM
tpierce
Audi Original "S" Cars
Aug 17, 2004 07:25 PM
chuck
Dec 16, 1999 09:53 AM
