lots of problems, big car day(kinda long)
Old Dec 4, 2001 | 03:22 PM
rocketaudi's Avatar
Default lots of problems, big car day(kinda long)
ok so heres my story. yesterday i decided it might be fun to tear out the sound systems from 2 of my old cars and stuff it all into my 4kq, and my new 5 cyl fuel pump relay just came in so i was gonna put that in too... it all went pretty much without a hitch until i finished up. heres the sequence of events. i wired the whole car with the speakers, head unit, amp and sub. before i tried it out the relay came in the mail so i quick went and changed it and tried it out. i turned the car on, it started up fine, revved fine and everything. satisfied, i went back to finish the audio stuff. i got it all done and tried it out and the head unit didnt turn on. so i checked the fuses, found a burnt out one and replaced it. the radio turned on fine and everything was happy. now to add more mystery to this story, behind where the radio goes in the center console theres a metal brace that has a little siver box attatched to it that plugs into this big plug. i dont know what it is. its been unplugged for a few months now and the car has been running fine so since i was in there i plugged it back in. i put the whole console back together and started the car...now it gets funky... it turned and turned and finally decided to catch but idled badly around 500rpm. so i drove it around a bit, theres a huuuge loss in power, tried it without the fuse that was bad, everything i could think of and nothing helped. then i unplugged that shady silver box and now it idles around 900 rpm but theres still MAJOR power loss. i need help!!!! my car needs help! please help me!!!!!! thanks
Old Dec 4, 2001 | 03:31 PM
Chris in VA's Avatar
Junior Member
Default Eeek
I hope you didn't fry out something important. When my car did that, I found out my CPU had 8oz of water in it from a leak in the firewall...
Have you checked fuse #24 yet?
Old Dec 4, 2001 | 04:52 PM
CGTCOMM86's Avatar
New Member
Default it's probably...
the big silver box is your diagnostic computer... leave it unplugged, those things ten to go insane as the car gets up in mileage. it sound like you may have killed your voltage regulator, i did that in 4kq and everytime i slowed down, the car almost died. dramtically changing the voltage flow (like with a sub and cd player) can be the last straw for the voltage regulator... you can get a new one for about $30 anywhere, so you may want to do that first.
Old Dec 4, 2001 | 07:16 PM
86 Gt commem.'s Avatar
Default Re: lots of problems, big car day(kinda long)
I agree, its probably fuse 24, Its not a spare! My car would barely run without it, would not rev past 5,000 RPM
Old Dec 4, 2001 | 07:36 PM
rocketaudi's Avatar
im going to check fuse 24 now.. ill let you all know thanks
Old Dec 4, 2001 | 09:47 PM
Evol's Avatar
that silver box is your cruise control computer
Old Dec 4, 2001 | 10:13 PM
rocketaudi's Avatar
Default fixed!!!
my dopey friend unplugged the jetronic bc the glove box was in his way to put in the right front speaker and forgot to plug it back in. ugh, what an ordeal but oh what a difference it makes to be able to rev 6000 with the stereo on.. now this little silver box... diagnostic or cruise control? bc i unplugged it and my cruise doesnt work but im not sure if it did in the first place.. anyways thanks to all of you for making my day
Old Dec 5, 2001 | 03:51 AM
dB's Avatar
dB
That silver box, I believe, is the cruise control control. (control control control ....)
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 5, 2001 | 03:52 AM
dB's Avatar
dB
There should be a larger black box mounted under it. That's the knock/ignition computer
Old Dec 5, 2001 | 02:45 PM
rocketaudi's Avatar
Default no black box but..
theres a connector that comes off the cruise computer connector with 4 holes, looks just like a window swith connector.. does that go anywhere important?
