springs
You pay a deposit per item, but get all of your deposit returned when you return the tools. All in all, it's a great service.
When I did the struts on my 4000, I had a garage near my house impact off the very top nut (and retighten with a manageble torque for my hand tools), then I drove the car home and set to work.
The strut tower can be removed from the vehicle with out spring compressors, however, a spring compressor MUST be used when you loosen the strut mount bushing (the circular nut with two slots that sets the strut mount).
Once the springs are compressed, take a screw driver to the strut mount bushings and tap on alternate sides with a hammer to loosen the strut mount bushing. (It should come off with just a little effort).
Your strut mount should slide right off once the strut mount bushing is removed. If you are just changing your strut mounts, put the new mount on, screw in a new strut mount bushing, and away you go to the alignment shop.
If you are changing struts, remove the spring and spring plate, secure the strut housing in a vise or other object (a dumpster worked perfectly fine for me) and unscrew the strut cap with a pipe wrench.
Once the strut is out, reassemble, reinstall, align and enjoy.
-- tom
