What's the best way to remove foam 2-sided tape?
Old Dec 6, 2001 | 12:46 PM
Evilclown's Avatar
AudiWorld Uber User
Default What's the best way to remove foam 2-sided tape?
I've got a piece of weatherstripping that was held on by foam tape, which has come loose and caused the weatherstripping to sag(it's the piece across the top of the windshield). I've got some good adhesive to put it back up with, but I need to get the old stuff off first. Any suggestions? I don't have access to professional-strength stuff, rubbing alcohol doesn't work, and sanding will take too long. TIA.
Old Dec 6, 2001 | 02:30 PM
Jamie '87 CGT's Avatar
New Member
Default Re: What's the best way to remove foam 2-sided tape?
I have used "goof-off", and also wax remover, we sell some stuff here at work, but mainly buy an adhesive remover, and sticker remover, and let that stuff just soak in like crazy, try to cut off what you can ,like with a small razor, just rewax any exposed painted surface, Jamie
Old Dec 8, 2001 | 09:06 AM
Seattle Scott's Avatar
I'd try Goof Off too but remember it is nasty stuff.
Old Dec 9, 2001 | 07:55 PM
Evilclown's Avatar
AudiWorld Uber User
I've never seen that around here. Who carries it?
Old Dec 13, 2001 | 09:27 AM
cdunlap29's Avatar
New Member
Try that nasty citrus ****. It should work
Old Dec 14, 2001 | 05:15 AM
vtecetr's Avatar
New Member
Default Re: I've never seen that around here. Who carries it?
do you have a auto body supply store around you?
they should carry some stuff called 3m adhesive remover or some thing in the same ball park area . this stuff works great it cleans off all achesive based materials and then preps the surface for remounting all in one step!!!
ELEVENS
Q5/SQ5 MKI (8R) Discussion
Apr 1, 2012 05:59 PM
NeimanTT29
Mar 21, 2005 07:59 AM
Pie4Foo
Apr 5, 2004 01:05 PM
audiback wagon
Audi allroad
Nov 24, 2002 10:31 AM
CupS4
Auto Detailing Discussion
Nov 29, 2001 06:04 AM
