new rotors
Old Dec 8, 2001 | 08:11 AM
rocketaudi's Avatar
Default new rotors
the right front rotor on my 84 4kq is all chewed up and gross. are there any better ones than the blaufergnugen ones? any comments on the blau rotors bc it looks like thats what im getting..
Old Dec 9, 2001 | 04:40 AM
SteveAngry's Avatar
Default Balu rotors are just...
The ATE power disc's right? I used to have them on my 5000 w/ Metal master brake pads and they were OK. Nothing spectacular...
I've moved on to Zimmerman rotors and Jurid pads and they seem to be just as good...
Steve
Michigan
Old Dec 9, 2001 | 04:11 PM
1hot4000s's Avatar
New Member
Default Brembo.
i got full brembo brake set on my car......nothing beats it.
Old Dec 10, 2001 | 08:19 AM
874000Q's Avatar
New Member
Default ATE's aren't good?
Steve, a little off the subject. Building an '84 GTI as a FSP Autocrosser and was recommended that we put ATE Power Discs and Mintex Red Box Pads if we want to keep stock sizes and calipers. Is this a less than desirable setup?
Old Dec 10, 2001 | 04:13 PM
audinutt's Avatar
25 Year Member
Default Re: ATE's are good!
Use the ATE pads with the ATE rotors...
works great on my 4kq! but then again i upgraded
to 90 brakes and rotors..
but the ATE pads are organic and don't ruin
the slotted rotors like semi-metallics do.
HTH!
rich
'86 4kq
BTW, the ATE pads can be purchased from the parts connection.
Old Dec 11, 2001 | 07:12 AM
SteveAngry's Avatar
Yeah, I think that on my heavier 5000 the combo of a metallic pad and the ATE rotors just wasn't all that great. Maybe those ATE or non-metallic pads would have made a better choice. My ATE rotors got shredded with the Metal Masters...
Steve
Michigan
Old Dec 11, 2001 | 04:28 PM
audinutt's Avatar
25 Year Member
yeah.. the ATE pads are organics..
metal masters will chew thru rotors (especially slotted)
HTH!
rich
'86 4kq
Old Dec 11, 2001 | 10:21 PM
cdunlap29's Avatar
New Member
Default Re: new rotors
get the brembo OEM rotors I had them on my old 4k and they worked great and they held the machine lines for awhile so they looked great too
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 14, 2001 | 11:36 PM
Pawl-X's Avatar
New Member
Default Re: ATE's aren't good?
I Have them on my car! They rock! No fade and bad a$$ in the rain!
igor_grits
Q7 MK 1 Discussion
11
Aug 11, 2015 10:59 AM
q2quest
18
Jan 17, 2005 02:14 AM
BVRN_RKT_94_90
Apr 26, 2004 05:13 AM
flash123
Jul 6, 2003 11:44 AM
deosola
Feb 21, 2002 11:11 AM
