hesitation
Old Dec 11, 2001 | 08:29 PM
84CGT's Avatar
New Member
Default hesitation
I don't know what it is but it just started tonight. Whenever i accelerate the car has heavy hesitation, when it gets up to speed it kinda shakes and feels like the tires have no traction even on dry ground. I think it might just be some bad gas but have you guys ever run into this problem?
Old Dec 12, 2001 | 04:58 AM
vtecetr's Avatar
New Member
Default Re: hesitation
YEA AS SOON AS RAN SOME BP GAS THROUGH MY RIDE ENDING UP REPLACING FUEL FILTERS AND INJECTORS BECAUSE THAT ICE GAURD SH*T melted the needle portion of the injector so never the less i do not put bp gas in any german car now!! so more than likely it sounds to me like you got some bad fuel or even a pluged filter or injector. if you remove the fuel lines from the injectors there shouldl be a little steel mesh filter check it to see if is clean of debris (small rust particles etc.) also you didn,t lose a foil protection cap when adding any additives to your fuel ?
Old Dec 12, 2001 | 05:04 AM
84CGT's Avatar
New Member
Default I haven't added any additives to the fuel lately
I also noticed that my exhaust is disconnected right after the catilytic converter could that be what is causing the problem?
Old Dec 12, 2001 | 01:07 PM
84CGT's Avatar
New Member
What are some symptoms of bad gas?
Old Dec 12, 2001 | 04:37 PM
vtecetr's Avatar
New Member
Default Re: I haven't added any additives to the fuel lately
no not really actually you should have a little more power!
Old Dec 12, 2001 | 04:39 PM
vtecetr's Avatar
New Member
Default Re: What are some symptoms of bad gas?
hesitation,hard to start,misfire,backfire,rough idle,won't start,etc etc
Old Dec 12, 2001 | 05:59 PM
Chris in VA's Avatar
Junior Member
Default My 86 had this
A couple years ago I thought I had bad gas...and I mean REALLY bad gas. Hesitation, backfiring, black smoke, no power etc. So, after a couple days of this, I gave up trying to find the problem and took it in. Guess what? It seems I had a hole on the passenger side in that little area where the intake is for the HVAC. Over time it dripped down, directly onto the wires for my CPU located next to the glovebox. The water travelled along and collected INSIDE my CPU case...8oz worth! The *genius* mechanic actually poured all that water out in front of me...what a shock! New (used) CPU from Shokan and I was good as new.
This probably isn't your problem, but thought everyone might want to know about this veeeeeery strange incident.
Old Dec 12, 2001 | 06:19 PM
84CGT's Avatar
New Member
Default Thanks i'm pretty sure its bad gas
Its hard to start, it idles rough and it has no power good thing i am almost out of gas now i can hopefully have a nice running car back
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 13, 2001 | 01:16 PM
84CGT's Avatar
New Member
Default Well its not bad gas
I put more gas in and it is still running pretty bad. What else could it be i'm really getting frustrated with it.
Old Dec 13, 2001 | 02:01 PM
mgs1's Avatar
try checking the ISV
