Cold Air Intake?
Old Dec 12, 2001 | 02:58 PM
Tylerb929's Avatar
New Member
Default Cold Air Intake?
I realize that Audi didn't take much time in designing the box for the air filter because it is a pain to replace the air filter. There are also no cold air intakes for them either so what I have planned to do is just remove the air filter from the box and put a cone on the end of the tubing where it gets air from. Sound like a good idea? or you think it won't help much?
Old Dec 12, 2001 | 06:13 PM
Chris in VA's Avatar
Junior Member
Default Re: Cold Air Intake?
Well, all's I know is using a cone on the INSIDE of the engine bay actually decreases power because once the temperatures climb the air gets less dense. I dunno about putting the cone on the end however. Someone told me a while back to drill some 1" holes in the airbox before the filter, but it doesn't seem to help much.
Old Dec 12, 2001 | 06:35 PM
Tylerb929's Avatar
New Member
Well the thing is the cone wouldn't be near any heat in the engine bay. It be getting air from the same place as the normal setup just you'd be getting more air.
Old Dec 12, 2001 | 08:35 PM
1hot4000s's Avatar
New Member
Default What i suggest
if your gonna do that man make a snorkle going below your front bumper get a cone put it on the hose incase it with the snorkle going too the cone put a heat shealding metal over the cone...your set
Old Dec 12, 2001 | 09:28 PM
Evol's Avatar
You can't do a cold air intake on a CIS injected car.
Old Dec 13, 2001 | 03:03 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: You can't do a cold air intake on a CIS injected car. Wrong!
<center><img src="http://www.eurosportacc.com/images/prod/coolflo3.jpg"></center><p>
Plus I fabricated my own by running a 3" hose to my airbox lower half, on my 86' Coupe GT!
Worked like a champ!
yus
Inline-5 Discussion
Aug 9, 2006 08:13 AM
mhb_1323
Aug 19, 2005 07:20 PM
Murph
May 20, 2005 03:49 PM
byron - b'rizzle
10
Jun 30, 2003 07:36 PM
ludykriz
Feb 11, 2003 06:46 AM
