3B into 84WR - rear diff
Old Jun 27, 2005 | 12:16 AM
niall1's Avatar
Default 3B into 84WR - rear diff
Just want to check with you guys which rear differential you recommend with a 3B swap? We have swapped the engine and transmission from an Audi 200tq and that has a torsion diff and i understand a different ratio on the rear than the ur?
Thanks
Niall
Old Jun 27, 2005 | 04:58 AM
ralleyquattro's Avatar
Default Use the 200q 20v tranny...... with a 4kq rear diff
It has the 4:11 final drive yet a nice gear ratios for the highway... a nice compromise between the 4kq 4:11 and Ur-q 3.90.
You need to change your rear diff to one from an '84- early '85 4kq (large singe piece casting).
On the tranny, you'll need to swap the speedo sensor and the drive gear, not a big deal at all.
Torsen is very nice with the 20v...
HTH
Martin
www.quattro.ca
Old Jun 27, 2005 | 01:43 PM
Berserker's Avatar
Default Martin, what about the shift linkage?
I was talking to Ken Fluhr the other weekend at the USGP and he said something about having to modify/fab a new shift linkage if switching to the 200q20v transmission? Was this the case on your car, or did the stock linkage work fine?
Thanks!
Nathan Engelbert
83 UrQ DA900453
89 90q
91 200q20v donor
91 200q20v avant
Old Jun 27, 2005 | 01:45 PM
Rich L.'s Avatar
Member
Default is it a 10v or 20v 200 tranny?
The 200 10v and the 5000q both use the same 3.89 gear ratio as the urq. A 200 10v has the torsen (torque sensing) differential but they've both got pretty tall gears. Like Martin says, if you're up for swapping the rear end too, going with a 4.11 gear ratio is nice.
Old Jun 28, 2005 | 04:28 AM
niall1's Avatar
Default 20v :-)
20V
Old Jun 28, 2005 | 04:30 AM
niall1's Avatar
Default Re: Use the 200q 20v tranny...... with a 4kq rear diff
Martin thanks for the invaluable info - now to translate... Is the Euro equivalent of the 4kq the 80/90 quattro?
Old Jun 28, 2005 | 06:17 AM
Default Since it's a 016 the linkage is the same... you will need to relocate one shift linkage pin....
but that takes all of 10 seconds..
Old Jun 28, 2005 | 06:18 AM
Default Euro '84 4kq is 80 quattro, Euro '85-'87 4kq is 90 quattro......
The Euro '85-'87 4kq with 4 cylinder engine is 80 quattro.
HTH
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 28, 2005 | 10:56 AM
Berserker's Avatar
Default That's what I thought
Thanks!
big_anthoiny
11
Sep 6, 2007 12:15 PM
MikTip
9
Apr 14, 2007 08:46 PM
moribundman
12v V6 Discussion
Aug 27, 2003 05:52 PM
90/90Qs
Dec 10, 2002 05:37 PM
NickS
Dec 7, 2001 05:43 PM
