Trying to gather information about doing a B3 2-piece strut housing conversion on CGT
Old Jun 27, 2005 | 06:02 PM
Skyler@Achtuning.com's Avatar
Member
Default Trying to gather information about doing a B3 2-piece strut housing conversion on CGT
I need new strut housings and was thinking of using the 80/90 front 2 piece struts on my 84 CGT due to their different brake caliper mounting. (yes still thinking of a too big brake kit)
Just wondering if anyone has done this before or if there are any unseen difficulties (4x100 hubs in B3 housings etc..)
I'm thinking of doing this mainly because of my lucky situation with work and being able to get Stoptechs help with some custom ST-40s and 332 rotors. I know this is way more braking than I will ever need but it sounds like a fun project as long as it does not break my wallet.
I'd appreciate any advice or feedback, even if you think I'm a fool just let me know why...
Old Jun 28, 2005 | 06:10 AM
Mr.FRU-T-Pants's Avatar
Default Skyler, might want to try the Coupe GT/4000 forum.
Our bolt patterns are different than yours, and don't require upgrades to the housings for BBK's.
I wish I could answer your question, but unfortunately...
On another note, what ever happened with the Piloti rep? Seems he had trouble getting in touch for a follow-up. You guys still have interest, or has that waned? Still love to hook you guys up as a retailer. The shoes are getting pretty hot now, and we've got lots of new drivers in them now. Working on getting Danica P. in them at the moment. Feel free to email me on yours or Josh's behalf.
Cheers,
Patrick Miller
Old Jun 28, 2005 | 10:38 AM
stevenmurray's Avatar
Default I have a bent urq strut housing - any cheap substitutes (like B3 stuff )
Someone was telling me I can convert to the 80/90 struts - but I have my doubts (re:front end).
steve
Old Jun 28, 2005 | 12:22 PM
Rich L.'s Avatar
Member
Default No such thing as "too big."
<center><img src="http://pictureposter.audiworld.com/671/stoptech.jpg"></center><p>If you can find urq struts, the A4 StopTech kit is a bolt-on.
Old Jul 1, 2005 | 10:29 PM
Ken CGT's Avatar
New Member
Default my brother Eric Fluhr is doing a B3/B4 strut conversion on his Urq
Eric will put it up on his website when it's done, but we are running into some problems with the rear setup. We have been at it for over 6 months now. Lots of buying parts that we can't use, basicly trial and error.
Old Jul 1, 2005 | 11:07 PM
Ken CGT's Avatar
New Member
Default Re: Trying to gather information about doing a B3 2-piece strut housing conversion on CGT
Why do you need a stoptech kit? You are right they are way over kill for a CGT. You probably know this but RPI sells a wilwood kit, that is for the 4X100 Coupes (don't try getting them to send you the 4X108 cars). I made a simply wilwood kit for my fathers 82 coupe turbo, which is a track car, and they work great; at least he loves them.
Well to answer your question, yes you can convert to two piece struts on a CGT. My CGT has been running them for about a year now. What I did was use 90 10v 75mm two piece struts and replaced the ball joints, CV joints, tie rod ends and either coilovers or 90 springs (lowering or stock). The spring perch on a 90 is about a 1/2 inch higher than the Coupe's. But it's a simple conversion especially if you get all the stuff from the donor car. As for the CV joint I uses a rear CQ outer joint and put it onto a CGT drive shaft. A front outer from a 90 10v may work but I not 100% on that.
I did this conversion, like you, in order to get bigger brakes. My car is running an Urq brake calipers and rotors which are awesome.
There is another option you could use a 1988 80 4 cylinder one piece strut. That strut has the larger brake bolt pattern (I call it a 4 inch pattern, vs. the CGT which is a 3 inch and new A4 which is a 5 inch). This one piece strut, from what I understand, is a direct fit with the CV joint, ball joint, and tie rod of your CGT.
Old Jul 2, 2005 | 06:00 AM
Default Ken, he works at Achtuning, which is a Stoptech dealer.
My guess is he gets wholesale or better on the kits, which makes it a bit more affordable.
Having said that, I have a set of UrQ front and rear brakes I'll sell you, Skyler.
Old Jul 2, 2005 | 05:42 PM
Default Eric Fluhr is doing a B3/B4 strut conversion on his Urq
Fluhr I remember the name - thinking you're from texas and helped the guy with the red urq ($2500).
I'm just interested in converting the front end for now.
steve
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 3, 2005 | 12:18 PM
Member
Default Thanks for the info, some good stuff there!
Sounds like the 88 80 Strut would work best for my needs as long as it fits all the CGT parts.
Thank you
Aug 15, 2006 02:43 PM
14
Aug 3, 2006 01:05 PM
Jun 28, 2005 06:32 PM
Jun 27, 2005 06:31 PM
wisconsin_quat
May 5, 2003 11:26 AM
