Questions on urq not starting/firing...
Old Jul 19, 2005 | 01:40 PM
mtaudi's Avatar
Default Questions on urq not starting/firing...
I got the urq back from the shop after turbo and injector replacement and the next day wouldn't start. Just turns over-no spark. Also no dash power. Brought it back and they were able to get it running by jumping the coil from a hot lead in the engine compartment. Once running the dash had power as well. If jumper is removed then car dies but dash has power until key is turned off. Problem is their schematics don't match what's in my car. My bentley starts at year '84 so I don't think it will be of much help. Any suggestions?
Old Jul 19, 2005 | 03:20 PM
urq20vt's Avatar
Default 1. Ignition switch 2. Fuse box
The ignition switch is the most likely candidate (and fairly cheap), then the fuse box and connection (C15). There is no fuse on that line, so it should be easy to find.
The schematic shown in the red Bentley manual for the '84 is actually for the '83. The '84 schematic is not in the red Bentley manual.
Old Jul 22, 2005 | 05:37 AM
mtaudi's Avatar
Ignition swith cheked out o.k.-checking the fuse panel-Thanks and will post followup.
chenishead
Feb 14, 2008 05:19 PM
kelleypb
Jan 15, 2008 06:53 AM
Joey T
Dec 24, 2007 11:47 AM
tjf
Apr 5, 2007 08:19 AM
Tom Faust
Feb 23, 2005 01:07 PM
