UnderPressure help with 7a turbo
Old Aug 7, 2005 | 12:47 AM
pastures16's Avatar
New Member
Default UnderPressure help with 7a turbo
i know some of you lads out there have done this i just cant afford an s2 at the moment can anyone point me in the right direction on what to use ive found an s2 3b/aby block can i put the 7a head on it as the 3b manifolds are the same stud pattern do i need the water manifold? and why is there a blank where the oil pick up pipe should be any advise whould be a great help
Old Aug 8, 2005 | 04:02 AM
UnderPressure's Avatar
Default Re: UnderPressure help with 7a turbo
My conversion was done by the previous owner but it's based on a 7A block and head. The bore is different between the 3B and 7A so there would be a fair bit of work to get that to match and gasketed. I'm not sure about piston to valve clearance either. Maybe someone else who is more familiar with the details of 3B vs 7A can chime in.
Avant20v
Aug 3, 2011 02:27 PM
Eric NY
Jan 25, 2007 12:04 PM
RichieB5
9
Apr 19, 2006 03:59 PM
pastures16
Aug 15, 2005 09:52 AM
SLAB
Jul 27, 2004 09:46 AM
