034 EFI BTDT?
Anyone recently wired a 034 IIC for a 10V and have pointers? I'll probably start the wiring this weekend.
Mike Bond
I used a factory audi rubber wiring harness boot at the firewall and set the 16 pin CPC connector close to the ECU.
From there I mimiced a factory Harness with Bosch junior connectors. REcommend Heat shrink tubing and Raychem tubing and labels. You can make the harness modular by using more quick disconnects like 8 pin CRCs etc. That makes it easier to modify in the future if you are so inclined.
if you can send it : d@dokeda.lt thank you very much
