UR-Quattro cat replacement
Old Oct 10, 2005 | 01:03 PM
rjhld's Avatar
New Member
Default UR-Quattro cat replacement
OK It's time to replace the old cat with a high flow one. Any recommendations from owners that have gone through this.
Thank,
Bob
Old Oct 10, 2005 | 02:52 PM
Tony@EPL's Avatar
Former Vendor
http://www.randomtechnology.com/ ... they are more expensive then most, but worth it.
Old Oct 10, 2005 | 07:16 PM
rjhld's Avatar
New Member
Default Re: http://www.randomtechnology.com/ ... they are more expensive then most, but worth it.
Thanks, Nerdhotrod it looks like one buys the generic 3" model and then has to modify the exhaust to make it fit.
Old Oct 11, 2005 | 06:44 AM
Mike Desi's Avatar
Default My OEM "test pipe" is high flow.
I noticed that the ETKA showed a part # for the test pipe, so a couple of years ago I gave the part number to my local dealer. He got it in! Luckily Massachusetts dosen't check emissions on vehicles 83 or older.
Old Oct 11, 2005 | 07:27 AM
rjhld's Avatar
New Member
Default Re: My OEM "test pipe" is high flow.
Thanks Mike, NJ does check emissions unfortunetly. However, in two years I can go as a historic vehicle and not have to go through it anymore. Bob
Old Oct 11, 2005 | 09:31 AM
OWDLVR's Avatar
Default you could also buy a Vibrant Performance cat
Metal core, flow benched to 578cfm.
you can order part number 7102 (3" metal matrix cat) from www.independenttuning.ca but you'll need to call or email them, it's not on the website yet.
-Dave
Old Oct 11, 2005 | 10:21 AM
ralleyquattro's Avatar
Some of those puppies had a ring restrictor in them.. check it out!!
Old Oct 11, 2005 | 05:37 PM
rjhld's Avatar
New Member
Default Re: Some of those puppies had a ring restrictor in them.. check it out!!
Thanks for the heads up. Bob
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 11, 2005 | 05:40 PM
rjhld's Avatar
New Member
Default Re: you could also buy a Vibrant Performance cat
owdlvr, Thank you for the link and info. I'll give em a call.Bob
Old Oct 11, 2005 | 07:27 PM
wurldpeace's Avatar
Default about to go through it
<center><img src="http://pictureposter.audiworld.com/53920/catoflife.t.jpg"></center><p>i just purchased 2 HJS race cats.
one is going on my urS6, but will work with any 3" exhaust.
it will need special fabrication to clear the bell housing, but this things a work of art. never seen anything like it until i researched.
i can currently only reccomend that you use v-band clamps to secure it and make friends with a local fabricator if youre going to go all out... or get something specific to the ur coupes and save a headache.
im difficult...
