Digital Dash
On the US spec models with the green Digital Dashboard, does the connector pinout on the dash match the same pinout on the red dash used on the later GT?
I found some usefull documentation on the GT dash at http://home.earthlink.net/~groovy_monkey/Audi/Digital_Dash/index.html
Also would anyone know if the Digital Dash used in the MB UR is the same as the one used in the US spec GT?
The MB/RR dash is not the same as the Coupe GT dash. I have both (MB/RR and CGT) and there are slight differences. One difference is a jumper (see below) and the other is a different processor. I _think_ the MB/RR dash has a higher redline (where the display flashes), but I haven't confirmed this yet. You can convert the CGT to work with the quattro by installing a jumper or switch right behind where it says "Q C" on the housing. This converts the full fuel capacity from 70 to 90 liters so the computer works properly. The pinout is the same, except for minor differences in the locations of the indicator/warning lights and the fuel consumption circuit.
Curiously enough it also lists the WR dash against the european GT, 80/90 (4000) and the Coupe Quattro (GT with quattro).
I have a copy of the pinout for the US spec GT dash (one of which is going into my 1985 CQ), but does anyone have a copy of the pinout for the early green dash?
Yes, the displays will actually work if you swap them around. Doesn't do much good as they only fit one way. BTW, be VERY careful with the LCD panels. Those connections are good only for about three connecting cycles before the plating wears off of the glass and then you are done...
I have a copy of the schematic for the green dash, but not in electronic form. Have you tried Phil Payne's site? That is, if it is still there...
I'll have another perussal of his site
