'82 Tresser quattro coupe turbo.....what's it worth?
The value of any ur quattro depends upon its condition. A car that hasn't run in years wouldn't be worth more than $2500 unless the rest of it is absolutely beautiful and in excellent shape. I know of a car that is in a shop here in CO that sat for 10 years under a cover, but in a very humid environment. Although it looks beautiful on the outside and has only 22k miles, it took $9k to get it road worthy (all new hydraulics, brakes, cooling system, bushing, steering, suspension). Word is that the new owner bought it sight unseen.
So, if you can't drive the car and check it out, don't pay alot for it. If the seller says that it will only need this or that to get it going (like that car in CA that said it just needed a $10 fuel pump relay), have them fix it and tell them you will pay $10 extra for the relay. If not, consider any non-working system (like the engine) as needing replacement or rebuilding and subtract that cost for the value. Considering what it will cost to repair anything on the car if you don't do the work yourself, non-running cars are not worth much at all.
If you look, you can find nice running ur quattros for reasonable prices. If you want to learn about the cars, and don't mind paying to learn, then get something that needs a lot of work. Chances are, it will cost much more to revive a rough car, than to just buy a good one to start with.
Just my $.02. YMMV...
